I need a pansat loader and bin
Username: Swirvin
Post Number: 15
and i'll do the rest i promise !!!!
i cant find any files that im sure are the right ones.
Username: Swirvin
Post Number: 16
pansat 2300a
Username: Ke5aqn
Shawnee, OK USA
Post Number: 20
Right now at this moment you have to turn off autoroll and put in keys with remote so a BIN would not help you much unless you want a channel list mabee..hope that helps
Username: Swirvin
Post Number: 17
well the key changing does not work for me. i have a older bin from june so i was wondering if that was the problem and would it work with a newer bin.
Username: Runnerguy
Pluto
Post Number: 15
Go to FTACentral dot com ....find files for 2300a
