PANSAT PRO,PLEASE HELP NEW USER
Username: Ben123
Post Number: 21
im using pansat 3500 and by mistake i have put bin for 2700 i think and now i have no power and ithink i have to load 356t using 3.40,how can i load now since power is not comming on my 3500? THX
i have tried everything to get power on TURNING ON AND OFF FROM THE BACK,UNPLUG FOR A WHILE PUTTING IT BACK but its just not comming on last night i was getting lil green light but nothing worked thats about it but now i dont even get that.
Username: Rcfiddlerman
you should reload the factory bin file for that model if the power dont come on while u first download the file try shutting it while u are downloading it it just might kick into gear
Username: Ben123
Post Number: 24
where can i get the factory bin for pansat 3500?
Username: Subzerocdn
Post Number: 30
go to the pansat home page...
Username: Bones714
SO.California
Post Number: 115
WWW.Pansatusa,com
Username: Ke5aqn
Shawnee, OK USA
Post Number: 18
Yes Alex go to pansat home...if you need me to find the link I can
