Don't use 2500 bin, yes it will not work and I strongly believe the bin u need is the same one that is used on the MS100 or the Digiwave 7000. Also u will need a null modem cable...Check it out.
i have read online in other places this file can be used for this box as long as its for clones etc...i have used the digi 700 bin before but not up right now so was just checking and researching to see if there is any other clone file that can be used instead of digi
