Sharing DN and FTA on One DISH
Username: 1tina_chick
Post Number: 45
" Sharing " a DN sub with a friend and a Cools*t + one Dave dish 2
LNB' s- well one double so that makes 3. Let's make all this cr*p
work together, any Ideas. ? The Cools*t is on a switch to split the LNB's
Username: Nikk
Post Number: 312
Tina...
Check the back side of the receivers for a "IF OUT" connector, if that exists just plug the other receiver right there.....
Post Number: 47
Nikk is that the same as loop ? it's a male cable connector
Username: Nikk
Post Number: 313
Yes it is the same.....
Post Number: 48
Thanks Nikk, is support for cool 4000 dead..... do they want us to buy a new box ?
Username: Nikk
Post Number: 314
Tina....
Maybe........
