Help with captive works cw-600s p
Username: Brucester
Post Number: 9
please can some one help i down loaded the new file cw 600v1.20 but still get scrabble ch on bev or dish did i do somthing wrong if so what bin do i need please can someone help me thanks
Username: Lebrimal
Post Number: 74
did enable the patch? press F1 + 000 you must see patch enable.
Username: Lklives
Post Number: 4132
U know its is not a stand alone fix and must do card sharing on your server..otherwise U just get locals on DN...
CW 600-S Premium 1.20 bin
This bin will improve channel changing speed when using a card sharing server it will also improve problems with glitching you will still need to provide access to your own card sharing server as with the last bin enjoy
Username: Saks4545
Post Number: 17
just wondering since captive works have the same conexant processor as viewsat, can they be modifed for use with viewsat bins, like you would modify the viewsat clone pantecs, is it worth a chance?
