Just Got my Viewsat Extreme Love it so far anyways I have sats Bev 91, 110 ,119 but no epg for bev in Guide just channel Numbers 110,119 show epg (show info)
found this on another site does it make sence because mine is showing as *Nimiq shows up as 90.9 W* ================================
no EPG with BEV
There are a receivers that ship with a sat file from the factory that is not quite right. BEV is listed as 90.9 instead of 91 and this causes problems with the EPG. This seems to mostly be for the xtreme that is effected by this problem.
Go to menu INSTALL Nimiq shows up as 90.9 W It should be 91.0 W On set up page for Nimiq scroll down to MOTOR. It should show OFF. Change it to USALS then click ok. You will see nimiq with a cursor . Click on that cursor. Enter 910 which will give you 91.0 and then use cursor DOWN key to get W. Click ok and save. It will say overload exit but say NO to the save prompt this time. Come out of install and go back in and you will see Nimiq showing 91.0W
Now change the motor to off again and exit to save. Try your guide again but you still might need to factory default and scan.
