The answer to life, FTA, and everything...
Username: Lkreturns
Gold Member Posts: 3827
Post Number: 27
The answer to life, FTA, and everything is...
not 42, but...
-Radio? Listen to the radio? It provides you with all entertainment ever needed? Radio dramas, radio talk shows, radio plays, radio comedies.
-Antenna TV? Get out the rabbit-ear antennas? That's what I'm using. Getting 4 channels, but that's enough.
-Free Cable? It's very easy to hook up your cable for free. Just get a long ladder to get up to the telephone pole where the cable goes in. Bring a wrench. Connect it, and there you go. (Make sure nobody sees you. 4am-5am on Sunday is the least trafficky time of the week.)
There. You. Go.
Username: F_t_a_is_back
Post Number: 166
I would like to try the free cable option but the line has a video blocker..any advice..
Username: Donnie1973
Post Number: 199
is it a small connector u cant get off, where the rg6 connector would go?
Post Number: 167
dan... yes...I was going to take it off but I would have to cut it off..not sure I want to do that..
Username: Lkreturns
Post Number: 28
i dont even know what a video blok'r is.
Post Number: 168
LK..I have roadrunner only, no video..it looks like a tube that blocks out video..only lets data pass..
Post Number: 201
its a filter. I have seen a tool that takes that off, also have seen a "homemade" one also. Engineer one my friend...
Post Number: 169
I guess I should stop being cheap and just sub to DN or Dave...don't know which is better..
Post Number: 202
LOL. If i could get cable at all where I live, I would climb and get it! Never shared a sub. LK knows about that.
Post Number: 170
Thats just it..the cable box is right in front of my house..they should not temp people like that..LOL
Post Number: 203
LOL.
Username: Hawaiian_time
Hawaii
Post Number: 362
Username: Bill_myres
Toronto,
Hey Dan can you please tell me how i can take off this filter. I will greatly appreciate that! Because i want cable! I live in Toronto and i already Rogers Internet. So can you PLEASE tell me how i can take off this filter. If anyone else knows how to take off the filter can you please post it.
THANK YOU!!:-)
Post Number: 204
I havent ever taken one off. U should be able to figure it out. Just dont mess it up to where u get into trouble.
Username: Damageinc
reminder: climbing poles with 30,000 volts at the top can be hazardous to your health.
lmao
is free Soprano's worth it?
Post Number: 205
Oh, the cable and phone lines are way below the big stuff. But do be careful. Make sure ur naked with latex paint all over befor u climb it though!!
Username: Lkreturns
Post Number: 29
Just take some wire-cutters, and cut the electricity cable so that there'll be no electricity to shock you. That way it'll be safe to do anything you want to the cable without endangering yourself.
Username: Lkreturns
Post Number: 30
Oh yeah--after you're done, just call the electricity company and they'll come fix the cut wire. For free, probably.
Username: Min
Post Number: 259
wait for the thunderstorm come,so it easier to climb up,than hold on to the cable wire slowly cut it in the middle thought...
Username: Mr_viewsat
Post Number: 51
wait untill you see a cop then clam over the pool
mother555555555
Username: Dicks_ndickweeds
Bonerland, USA Country Music
Post Number: 50
Just use a good left-over uhf antennae to get high definition and digital channels for free if you have such a television with a atsc and qam tuner.
Username: Totaldikguy
Post Number: 38
If you leave near the city:
Get all all/most of you local channels...
HERE is a good TV back-up. All legal with hi-def reception too.
http://www.pricegrabber.com/rating_getprodrev.php/masterid=12618402/id_type=mast erid
http://www.pricegrabber.com/rating_getprodrev.php/masterid=5433046/id_type=maste rid
Username: Bugster999
Katy, Tx
Post Number: 23
Tried using a small needle nose plier I think that will be able to get on it so you turn it. At least when I worked for cable that was I would do when I forgot the special tool they gave us.
Post Number: 207
LOL, LK. Yeah, call the cable comany too and make sure you connected it correctly.
