New member Username: Cucon1Post Number: 1 Registered: Jul-06 | Can I program or unlock a rom 102 DN card with a Mikobu III that was used for testing the HU card ? |
Silver Member Username: Donnie1973Post Number: 150 Registered: May-06 | yes... if modified is what I hear. |
Gold Member Username: GavincummNew York USA Post Number: 1255 Registered: Feb-05 | what is with the pron? |
Bronze Member Username: ShutdafucupPost Number: 13 Registered: Jul-06 | Mikobu III Gently lift pins 1 and 4 of the HC00 chip. Lift pin 10 on the 232 chip, if your board has a 233 chip then lift pin 1. Solder jumper from AT90S2313 pin 14 to HC00 pin 10. Solder jumper from AT90S2313 pin 18 to HC00 pin 4. Solder jumper from HC00 pin 8 to HC4053 pin 9 (the one to the left looking at front of loader). Solder jumper from HC00 pin 9 to HC04 pin 2. Solder jumper from HC00 pin 1 to HC74 pin 5 (located right above HC00). Solder 2.2k resistor or (trim pot not really needed) from card slot vcc to ground (c10 is close by). Install switch from 232 pin 10 (or 233 pin 1) to AT90S2313 pin 18 (on for flashing and off for unlocking. |
Silver Member Username: Donnie1973Post Number: 159 Registered: May-06 | what about a t911 programmer? loved the link there jack azz |
Bronze Member Username: ShutdafucupPost Number: 14 Registered: Jul-06 | t911 image is to large to upload. If shrunk, you will not be able to see where to cut traces on circuit board |
Silver Member Username: Donnie1973Post Number: 160 Registered: May-06 | cool, where could i see it? |
Bronze Member Username: ShutdafucupPost Number: 15 Registered: Jul-06 | I could email it to you. I get it from a pay site I belong to. |
New member Username: Cucon1Post Number: 2 Registered: Jul-06 | WOW ! thanks so much for the info John... I am really amazed ... Again, thank you John. |
Silver Member Username: Donnie1973Post Number: 161 Registered: May-06 | ok, i may regret this...lol danteintn@yahoo.com thanks john |
Bronze Member Username: ShutdafucupPost Number: 16 Registered: Jul-06 | No problem Dan. |
Silver Member Username: Donnie1973Post Number: 162 Registered: May-06 | U rock! Thanks a lot. Have been looking for this. |
Bronze Member Username: ShutdafucupPost Number: 17 Registered: Jul-06 | Your welcome |
Bronze Member Username: PopogrowPost Number: 14 Registered: Jul-06 | John can i use any box for the rom 102 card |
Bronze Member Username: ShutdafucupPost Number: 18 Registered: Jul-06 | No you need either a c*oolsat FTA receiver or a jtagged dishne*t receiver |
Bronze Member Username: PopogrowPost Number: 15 Registered: Jul-06 | ok thanks so all the dtv receiver that we use to use with hu cards are not good any more |
Bronze Member Username: ShutdafucupPost Number: 19 Registered: Jul-06 | That is correct. |
