Question
Username: Shafto
Cooper City, FL USA
Post Number: 10
Let's just say you moved your dish to another point in the sky and did a blind scan. And from that scan you got 21 transponders with Mid 70's on the percentages. Is there a way to find out which sat you are on if you did not know where you pointed from the names on the channels that came up from the blind scan?
Username: Waydown
Post Number: 69
yes, also there is a tv guide I use called ORBIT ,you can get a any gro. store.
