Silver Member Username: Lucia
Post Number: 210 Registered: May-06
Posted on Hey by getting the satmex does it work here in canada? |
Post Number: 211 Registered: May-06
Posted on oh let me rephrase that by getting the sat mex (121) do i get any free channels? and does it work here in canada? |
Post Number: 217 Registered: May-06
Posted on DAMMIT SOMEBODY ANSWER MY QUESTION!! |
Silver Member Username: Hardrockstriker
Post Number: 239 Registered: Apr-06
Posted on Lucia, sat mex 5 is at 117 deg, and yes you will get free channels as it is FTA. You will need a linear LNB, however, on your dish. Check out:
http://www.ftasalescenter*com/downloads/fta_channelguide.pdf (replace * with a dot) To see what FTA channels are available. |
Post Number: 218 Registered: May-06
Posted on THANK YOU SO MUCH JASON!!!! |
