Pansat help
Username: Jonas2410
Post Number: 15
FLASH UPDATE FAILED
Username: Evadelparaiso
Puerto Rico
Post Number: 1136
wrong cable
Username: Jonas2410
Post Number: 16
can't be don't mean to sound like a jerk but i have db9-db9 female to female for pansat 2500a it was doing the same thing with fortec then i changed loader name to "Pansat 2500" and it worked maybe i just got "Lucky"
Puerto Rico
Post Number: 1139
try with another cable, if you use null try with straight, try with another loader, another bin. Lucky
Username: Jonas2410
Post Number: 17
I just bought the cable "straight" what loader what bin i ask these stupid questions because i dont want to burn my dads box and have to give him mine. Unlucky
Puerto Rico
Post Number: 1141
At your own risk, of course. :-)
http://www.dss**tester.com/files.php?cat=14 (if you have pansat clon)
IF you have pansat original:
Pansat Files » Pansat.2500a.0608-BL
This the official Blacklist release for the Pansat 2500a fixing June 2nd PPV/XXX hashing.
Date: 09/06/2006 Download Pansat.2500a.0608-BL (533.32KB) at: http://www.dss**tester.com/files.php?cat=14&cmd=all&sort=&order=&page=2
pansat donwload area, go to search loader download the gt loader. Enjoy
ps remove **
Username: Jonas2410
Post Number: 18
will try again tomorrow thank you
Username: Budalica
go to http://www.cyberdbs.com and find the software called : Cyberdbs Nagra 2 tools
it will update keys for dishnetwork + bellexpress wu . as soon as dishnetwork changes keys you can find them there , and also tri installing nagra decrypter on your pansat . it works .
Username: Letmeon
Post Number: 34
keys are outdated...
get Keymaster.....
Username: Pham2929
Flash Update Fail
I am using a cable i bought from Radio Shack
RS 232C. for my Pansat 2700A.
Am I using the wrong cable ?
Puerto Rico
Post Number: 1169
Do you have the wrong cable, do you need Rs 232 NULL.
Username: Johnner
Miami, Florida
Post Number: 217
Go back to Radio Shack they have an adapter for the cable to make it from normal to null.
Username: Cosmic_ray
Toronto, Ontario CANADA
Post Number: 74
Try to contact PANSAT seller, for store location;
www.pansatusa.com
Ask NULL MODEM CABLE
Which is 9 Pin cable, MALE/FEMALE
Username: Aky
Canada, Ontario Canada
i just hear all reciver will be down after one weeks is it right
Username: Aky
Post Number: 8
can any one help me
Post Number: 75
Akysam !!
What is the issue ?
I have PANSAT working great ............
Username: Sarah73
Hey sorry to bother ya'll but I was just wondering if there are any fixes for the ppv/xxx on bev yet?
All other channels are working fine but I miss my ppv. I have a pansat 2700 and nim 2 . thatnks in advance. You guys arelways so helpful.
Username: Wkj
Pansat Problem - new topic. I loaded new 277 bin in my 2500A and got all channels back but my channel list appeared gone. Channels were all over the place. I didn't have a back up so I downloaded a list on line but it would not load with Channel Master. I then tried to upload my channel list and the one I uploaded looked nothing like any I have used. Now, the channel list appears to change almost daily on its own - channels are moved, duplicated, etc. My question is: Is the bin file the cause or is my 2500 not accepting the channel list correctly. Any help appreciated.
Username: The_wank_artist
Post Number: 1042
sarah,
272 bin for the pansat will fix that for you.
Mike,
If you're scanning the tp/sat/blind scan after you load the channel list, you will get dups.
Try a different channel list.
Or delete all channels, scan sats, upload channel list, then start from scratch.
Or you could also try loading the bin again.
Maybe try the clone safe on, 277T.
Post Number: 77
Sarah Mackenzie !!
Load BIN again and enter keys, keep autoroll OFF.
May be it will help !
