Pansat 3500S/SD Self Reboot Fix
Username: Evadelparaiso
Puerto Rico
Post Number: 1140
At your own risk:
http://www.dss**tester.com/files.php?cat=14 (remove **)
Download Pansat 3500S/SD Self Reboot Fix (659.88KB)
Username: Bryanpa
I have no channels, all I have is a black screen and is says the "bad signal or scrammbled". Will this bin fix my problem and has it been tested yet?
Puerto Rico
Post Number: 1154
IF you have only scramble channels, do you need stop all autoroll, excepts keys in your receiver, turn off the receiver in back button, turn on, set your receiver, stop auto dn, stop auto bev, set defaults keys. Enjoy. The fix its only for automatic reboot issue.
