Dp Lnb Set up and Tp edits
Username: Impala1977
Post Number: 13
I have a 2700a and I have been editing tps to vertical up to 32 tps. I have a DishPro Lnb running to my 2700a direct, no switch except for the internal in the lnb. Currently I get duplicates or more of the same channels.
Sat 119
Lnb type=standard
Lo freq= 11250
22kh= off
DiSeqC= #1
Pos. Set.=Disable
Sat 110 everything is the same except DiSeq is #2
My question: I just found on lnb type a Dish pro selection, if I change standard to this do I still need to edit tps at all? Also when I change to dish pro my 119 loses quality and level stays at 82% but my 110 is fine at level and quality.And what is the right way to edit tps? Change all to verticals up to whatever #? I understand 119 only has up to 21 tps so I changed everything to vertical and subtracted even number tps from 25600. I found a guide on d**tester about it but some the tps freq on his list are different that my tp list before i edit. How about 110? Change all to vertical but don't edit tps since they aren't there. I have up to 80 tps since I first did a blindscan, how do i delete them so I have only 32 tps?
Sorry for all the questions if anyone can guide me somewhere i can read and learn or point out what I am missing. Thank you.
Username: Lklives
Post Number: 3427
Change settings to DP, should get better signal...and ONLY do Vertical TP scans!...should get all the DP Tps then...the DP LNB's changes the horizontal TP's to vertical for U....no neeed to subtract unless u are making own channel lists!
For all who wish to use Dishpro lnbfs
Dishpro lnbfs are erronously being reported as not usable with Fta receivers because of internal switch. this is not true. You can use them with no additional switch needed. The only time you will need to use an additional switch is when adding a second dish to your system. Pro lnbfs have a built in DISEQC switch not a sw21 as the legacy twin has. You can easily identify pro lnbfs by a large black D/P label. All that is needed to use this lnbf is to connect 1 cable from lnbf to rcver. Each output on this lnbf carries both 110 and 119 signals. The different outs are for connecting additional rcvrs. Load a modified dishpro channel list or modify your own list by using Gtools or Channel master. To do this subtract all horiz. transps. from 25600. enter result as your new transp freq and change to vertical. IE. on sat 119 transp 6 is 12297h. doing the subtraction, you get 13303. So change transp 6 to 13303 and change h to v. Now you have 13303v And will be received dy dishpro lnbf's. To get a bit technical, the dishpro's use an oscilator that runs at 25600mhz. this is mixed with the horizontal transp freqs and new freqs are generated. If you should wish to add additional dishes to receive a third and even a fourth sat you must add a external 4x1 Diseqc switch. you must feed both port 1 and 2 with both(or in case of quad,2 )outputs. you can then add a third dish to port 3 and even a fourth to port 4. I hope this clears up the confusion.
_________________
DishPro and SuperDish TP freq. settings
1=12224,V,20000
2=13361,V,20000
3=12253,V,20000
4=13332,V,20000
5=12282,V,20000
6=13303,V,20000
7=12311,V,20000
8=13274,V,20000
9=12341,V,20000
10=13245,V,20000
11=12370,V,20000
12=13216,V,20000
13=12399,V,20000
14=13186,V,20000
15=12428,V,20000
16=13157,V,20000
17=12457,V,20000
18=13128,V,20000
19=12486,V,20000
20=13099,V,20000
21=12516,V,20000
22=13070,V,20000
23=12545,V,20000
24=13041,V,20000
25=12574,V,20000
26=13012,V,20000
27=12603,V,20000
28=12982,V,20000
29=12632,V,20000
30=12953,V,20000
31=12661,V,20000
32=12924,V,20000
DishPro TWIN or QUAD LNBs have an internal DiSEq switch and use an LO of 11250
For FTA receivers the switch settings are:
DiSEq1(or A) for 119(echo7)
DiSEq2(or B) for 110(echo 8.10,
Use no external switches unless you are adding a 3rd satellite/LNB to your system. You will also need to use a DP channel list OR manually edit the H transponders
_________________
For some unknown reason my DP has a magic # of 26512 instead of 25600. It might help some.
Very good info.
In mine TP 1=12223, not 12224.
Post Number: 14
Great info. Thank you LK.
