Poormans dish setup - 22khz ON or OFF???
Username: Dailce
Post Number: 10
Hi I've been trying to find information on this. I'm only trying to get 110 and 119.
I can point my 18" DTV Dish at 110 and I get 97% strength top and bottom.
When I try to add the 119 to it I only get 12%
I have a 4x1 Disq switch. I think I have them put in wrong???
What should 119 and 110 be in on my Disq switch? Should 110 be in the 1st lnb slot of the switch or second?
I think I had 110 in slot 1 and 119 in slot 2. Also, do I need to turn 22khz ON or OFF?
Thanks.
Username: Califirnia
For me, I put 110 on port 1 and 119 on port 2.
and both 22 khz to OFF.
I get 90% S 92% Q
Good luck
Username: Lklives
Post Number: 2794
Doesn't matter which port on switch, as long as the receiver settings are the same as actual port settings!
BTW...U don't have the 119 LNB aimed correctly!
Username: Dailce
Post Number: 11
How should the 119LNB aimed? I have a bracket/mount for the 110&119. 110 points straight 97%, and 119 is to the left of 110 (looking from behind the dish) - 119 is about 1 inch above 110 and tilted back about an inch, Is that right?
Username: Lklives
Post Number: 2809
sounds close...but it will vary depending upon where U live...use the sat finders files at dsstester.c*om
Username: Dailce
Post Number: 12
Thanks LK you are the best. I will let you know how things go tommorow. I am in Ontario Canada.
