Problems After Adding New Sat
Username: Conti
Post Number: 41
I just installed a new sat - 148.
I was getting 110 and 119. Now when I connect my pan 3500 SD, the signal is lost after a couple of minutes.
I did a factory reset, loaded factory bin. The loaded Bin 145. Scanned in some channels. Set Default keys.
Then the signal dropps again. Checking the keys, they look good.
What could be the problem ???
