Pansat2500a PPV Channels are gone
Username: Nick32058
Asdfvafdsv, QC Sdv
Post Number: 15
Loaded bin 273t Non of the PPV channels are working. Does enyone know why?
Please Help
Username: The_wank_artist
Post Number: 84
Read this link.
https://www.ecoustics.com/electronics/forum/home-video/219758.html
The truth is out there... in the threads...
Username: Nick32058
Asdfvafdsv, QC Sdv
Post Number: 16
Thanks
Username: Lklives
Post Number: 2333
Changing TP's are happening again.
Noticed that some PPV channels were not showing up with programming in the EPG, ie 514, 515 on Echo 8.6, and sure enough, they were blank channels
Solutions (saved the best for last. - do what works for you!!):
First try turning the receiver off and on, using the switch at the back, not the remote. This re-sets the computer - quick remedy, just in case it's not a TP changing problem.
If that does not work, then:
Use an updated channel list
If none is available, which is what I expect to be the case, then you have these options:
Nuke all channels and Blind scan the sat(s) again.
Blind Scan Polarity should be Vertical ONLY for DishPro LNB's
Note: On the missing or blank channel, press the OK button. At the bottom of the pop up screen you will see the sat and the frequency for that channel. Make a note of it.
Now, go into the TP Scan, TP selections.
You will note that the EXACT frequency for the missing channel is NOT listed. It's close, but no cigar. Therefor a normal TP scan will MISS the channels.
The TP scan will not find the changes because the frequency is not that of the listed TP frequency, It's just a bit off and that means the channels will be missed during a TP scan
Setting Default keys again, will also NOT bring in the TP changes.
Hint: every time I scan, I start with a different sat and save to SD after each sat scan. This way, I can choose the 119 and 61 combo as the starter CH load and just scan 110. Saves time in the long run. Just remember to delete any old saved combos that includes the newly updated sat.
BUT THERE ALSO IS AN EASIER WAY!! - WITHOUT NUKING CHANNELS!!
First, on the channel that says no signal, hit the OK button and write down the frequency of the changed TP and which sat it is on
. ie: TP 12600, sat echo 8.6
Go to installation menu and choose Advanced Scan
In the top row, manually enter 12600 as the frequency
Go down below and highlight Video PID
Press OK, wait for scan to finish, some 16 channels will show up in the above example, exit to programming and all will be fine...NO DUPLICATES EITHER!!
Now this is the long read to the solution, LOL, but it's gonna take you a lot less time to read and do it than it took for me to try and discover all these solutions - so that I may guide you to which way is best - and hopefully, you've learned something along the way
Username: Hitman295
Hi' I'm trying to watch bev tv but it seems to say waiting for picture forever lol. I did the parental control set already it seems to not be working at all for me. Can it be my singal reading is not strong enough , its at 65-70 % . thanks !
Username: Lklives
Post Number: 2336
the autoroll in entering the new keys..may take 1 hour and go to 1000%....put in on a dishnet channel and then the Bev..then leave it alone until its complete....DN had new keys last night..
Username: Lady_m
Post Number: 12
I've never heard of Bev TV until I got to this site. Can you guys tell me what Bev TV is?
Username: Lklives
Post Number: 2346
same as Dishnetwork or DirectV is in US...but it sucks in my opinion, and its Canadian satellite TV..many French channels..Bell Express Venue aka BEV aka BELL....but to each their own
