I just got my pansat 2700a help
Username: Vndpatel
mine just got blocked wat do i do? it came with the wire?
Username: Vndpatel
i have dishnet
Username: Rockey
Post Number: 36
wat do you mean blocked and tell us wat in ur using wat kind of dish you have
Username: Vndpatel
blocked as in it dosnt work. i have a regular dish for dish network
Username: Rockey
Post Number: 39
oh there are new codes bad time to buy for a newbie not being mean they just blocked the old codes so now everything outta control havics broke lose evry where itll be strainded out though dont wory keep researching around
Username: Lklives
Post Number: 1423
bob john...go to dsscommunity.c*om...great forums and we have the new keys today and bins that U can use them with...so U can be watching TV in 5 minutes if U know how to upload a bin and enter the keys..and thats bins for ALL Pansats and clones, and Fortec Ultra's receivers..!
bin 261-2500
bin 122-2700
bin 123-3500
bin 103T or 256T - Ultra's and Pansat clones..
Username: Sam_det
New yok, Newyork Usa
Key 0: 9E 5B 7A 77 C0 FE 91 CA 4D 2A DC 33 D4 CD E3 75
Key 1: C5 6C 66 89 3A 32 D0 C9 24 2B F0 4F 03 68 06 92
Username: Vndpatel
which bin file do i download. I currenetly have 144
Username: Aanaa
Post Number: 19
144 will works OK
Username: Vndpatel
Post Number: 7
sam the key 0 doesnt work
Username: Vndpatel
Post Number: 8
kep 01:FB D9 F2 D9 D6 C9 EF 7A 57 AD 32 24 67 42 6C E6
I just found that
where do i get bin file 122?
