Right now i have a 4x1 Diseq switch. i want to add another Pansat reciver. Do i just need to buy a splitter and have it connected to the diseq switch and then feed the two recievere from the splitter or if the need a new diseq switch. Please help.
Help just for U
You need another diseqc switch connected to the second outputs of the lnbs.That means you need lnbs that have dual out for 2 receivers.And a second switch.
you cannot hook up more than one reciever to a disc switch. it is used to hook up more than one lnbs to single reciever. you need to get a satellite splitter to use on more than one reciever (sharing signal from same satellite(s)).
