FTA receiver with the best working EPG
Can some of U tell me wich brand and model of FTA-receiver has the best working EPG on the market right now and why ?
Thankx for the info in advance !!
Also would like to know about this !
tho
I do not have an exact answer, but I believe those with a lot of memory (RAM) certainly will outdo those with less. My 2700A has only 8MB and no Real Time CLock and therefore its EPG is quite slow and limitted and it is even much worse if time is lost. Besides that, I do not have any complaint. It does work. The Pansat 3500 has twice the amount of memory *plus* a real time clock which will save the time when the FTA is powered off. It has to be better in terms of EPG.
Thankx for the info ! What about the viewsat 2000 platinum ? Can you compare it with the pansat 3500SD ?
Username: Ikaleem
Post Number: 56
C**lsat is best in EPG...my c**lsat is getting upto three days EPG
