Help with a Panasonic CT 27D11E
Username: Murano
Toronto, ON
I recently aquired a Panasonic CT 27D11E. Unfortunately I do not have the OEM Remote. Connected the cable and I get no picture just snow. I connected another TV and the cable is working. Now I went into setup and I am unable to change the setting from TV to Cable. As I undstand it the TV setting is for an antenna? Does anyone have any suggestions or ideas
jkjkjkkjkjkjk
TV is for an antenna. You can change the settings using the channel and volume controls.
