Radio & Music
Music Problem
I have a Fortec Ultra and have the most current bin file working good for the TV side. I do not have any music or radio. I use channel master to load my channels and they show up in the list but I can not switch from TV to radio. Anyone have any insight?
Username: Rzoo4u2c
Post Number: 36
Because the channel list you put in probably had no radio channel in it.
Music Problems
Hey RAC Thanks for the reply....the channel list that I used has all the radio and music listed.... it just seems that my music button on the remote will not switch over to the music.....any thoughts ?
I may try a new list and see what happens. Thanks
