Thanks LK. But you can go to ftacentralc.m or al7bar.t. Or any one of 25 other sites for them .
The spoons are gone.
Or get off YOURASS and do some reading or buy a good unit not LK'S cheapies.
MapleIsABtch
maple leaf you are the biggest dick ever man. ive been lookin on here for a while and all i can say is that you are a DIC|<! sheesh man. you are supposed to be helping now bitchn all the time coc|< face!
Maples Leach
Maple Leach just wants to make a buck selling his overpriced crap kissing Blacklist's yellowass, he likes the clone kills, he's with the stooges camp.
What kind of moron posts over 1,000 times on one board. This pencil necked geek has to get a life.
Hey Maple Leach, when's the last time you got layed... by a woman that is.
Chicken why don't you register. LOSER. Or don't you know your name.
CUPCAKE
Maple Leaf....Don't worry, U the Boss...this jirk stick is one of Silly Thilly-boys...Fvcking fruitcake being s-u_c-k dick to much...ROTF -U know Thilly-1951 won't go away because no other sight will put up with him....B1tch-boy fvcked Thill and got him banned from this sight. The other two azz ooooooo are (31-4-skins) and The Hitch-e-b1tch-e-boy....This sight is good now that these three fvcking morons are gone.... Long Live the Maple Leaf....ROTF
EXPRESSVU
WWW.BESTFTAFILES.COM HAS NEW NAG2 FILES AND BELL EXPRESSVU SETUP.
Both the latest kets and how to input are posted at www.dsstester.c*om Forums and www.dsscommunity.c*om Forums...use the SEARCH feature there or U'll find the EDIT keys info in the Pansat area and the keys in the Keys area..
As a new member all I am learning is some new four letter words. If this seems to be the way to go, then I am an outsider. All I wish to know is if there are any 4000 PRO users here who would tell me how to reset the default key? Thank You, I would appreciate hearing from you.
Clifford...do not use these forums ...U will learn nothing here but profanity..go register at some real DSS sites and post your questions and read the How To manuals there..
Changing Your coo*lsat 4000 keys (Step by Step) Illustration Before you can accomplish the folowing intructions you will need Keymaster 2.0. I can only illustrate intructions without the keys. You will have to use the Keymaster 2.0 to obtain the current keys.
MANUAL KEY ENTRY INSTRUCTIONS FOR COO*LSAT PRO 4000:
Instructions for Dishnet: Find and select satellite tab: NAGRAVISION (00 01)
Once you locate the above mentioned tabK You must change the values of that screen to this:
10: XX XX XX XX XX XX XX XX 11: XX XX XX XX XX XX XX XX 00: 00 00 00 00 00 00 00 00 01: 00 00 00 00 00 00 00 00 and save it.
If the above key entry instructions does not work for you on dishenet (NAGRAVISION (00 01)? Change it to the instructions indicated above to the one illustrated below:
(Remember: This XX characters whould be replaced by the actual keys from keymaster) The zeros are actual key entry values needed, to make it work.
20: XX XX XX XX XX XX XX XX 21: XX XX XX XX XX XX XX XX 00: 00 00 00 00 00 00 00 00 01: 00 00 00 00 00 00 00 00 and save it. (Notice: That the #10 and #11 above are now #20 and #21 on this sample) On some receivers, this is the only way it works! For Bev Select satellite tab: NAGRAVISION (08 01)
BEV= Provider 0801 Nimiq N2 Keys
Must change whatever contents on this screen to CURRENT keys: Remember: Because I cannot actually provide you with the keys, I can only illustrate what to do. You must adquire the real values using Keymaster 2.0
Remember... No keys are allowed to be diplayed by the rules here, so I can only illustrate intructions without the keys. You will have to use the Keymaster 2.0 to obtain the current keys.
Key : xx xx xx xx xx xx xx xx Key : xx xx xx xx xx xx xx xx
A walk trough illustration of what to do: (To enter keys manuallyfº
1) Turn On Receiver 2) On the remote control press 8282
When the key window appears:
On the top of your screen, you will see many tabs with options like Saca, Nagravision, etc. Scroll left or right until you find the one that has the following information on it:
NAGRAVISION (00 01) When you find the tab that matches the items mentioned aboveK
On the bottom of that NAGRAVISION (00 01) tab or choice, you will see a window with four lines, which contain letters and numbers'K Scroll down using your remote to the first line with the letters and numbers and make the following changes indicated below:
Note:
The following illustration below is only used for as a guide to illustrate to you what to do. It does not necessarily mean that you will find the same letters or numbers displayed below: (they more likely to be much different) But. I use it to guide you in the process to show you what to do:
It would look something like this below:
(Remember: This XX characters whould actually be different in your receiver. You can find the actual keys from keymaster) The zeros are actual key entry values needed, to make it work.
11 XX XX XX XX XX XX XX XX 10 XX XX XX XX XX XX XX XX 00 XX XX XX XX XX XX XX XX 01 XX XX XX XX XX XX XX XX
Change all of that to this: (Remember: This XX characters whould be replaced by the actual keys from keymaster) The zeros are actual key entry values needed, to make it work.
