Can anyone help me out where I could find the new bin file for Telsetar 5 or the new keys for a pansat 2500.
thanks
troy2388
you dont need no key or new bin for t5, its internationl is it. all you need is a 30 inch dish and load in t5 sat and blind scan or just scan for channels.
honestperson
wait...let me pull that bin out of my a-s-s and give it to you
ladies and gentleman this is the process to get video/audio in pansat 2500.
1. Menu button, then scroll down and Select Parental Controls goto 2nd PIN/enter 0000.
2. Scroll down down to Nagravision press OK.
3. On the Provider ID, change the provider ID to 0001, then you will see dishnetwork right above the provider ID box, and Nagravision 1 on the top left.
4. Scroll down to key number box, Press the RIGHT ARROW twice(2 times), and you will see Nagravision 2 on the top left.
5. Make sure Nagravision 2 on the top left, and key # is 00, in the KEY DATA box, enter the new N2 key 00.
6. Make sure Nagravision 2 on the top left, and key # is 01, in the KEY DATA box, enter the new N2 key 01.
7. Confirm the N2 key 00 & 01 are correct, then press OK to save the new key. The press EXIT a few times.
8. Reboot the receiver by BACK of box, power off, wait 2 minutes, power on, now watch TV.
I hDISH NETWORK
12-06-05 Idea Key 1: F2 98 74 44 1C 65 77 D8 17 E3 E1 1D 89 4E 53 45
Idea Key 0:... ACTIVE 3D 73 19 22 27 5D C2 C9 97 96 5A 0C A5 79 27 F9
For Dishnet...
Coo*lsat Slot 10 and 11 are for Idea Key 1 and Slot 20 and 21 are for Idea Key 0
Pansat key 00 for Idea Key 1 and Key 01 for Idea key 0
Viewsat line 08 and 09 for Idea Key 1 and lines 88 and 89 for Idea key 0
For Receivers with only two Key Slots, Enter ACTIVE Idea Key into 00 and 01
All NEW Pansat SUPERBINS with AUTOROLL are posted at BOTH www.dsstester.c*om and www.dsscommunity.c*om ...Forums..Pansat...newest releases area (there they all are)...also a NEW safe bin for CLONES and Pansat 2500,clones, Fortec Ultra, pantec, MS etc..
