Techsat loader
hi i am having dificulty loading techsat can some body please help what loader,cable and file can i use thanks
Username: Thehitch
Fla.
Post Number: 79
Hi Alfin, you need to read. The info is in this list of threads if you`ll just scroll down about thirty posts. Look befor you leap!
hi i used the lemon loader with lemon picture and i used both kind of cables but whene i shut the power and turn it on i get blank can you please tell me what i am doing wrong thanks
Username: H3lt3r_sk3lt3r
Post Number: 559
Ctrl+F is a great n00b tool.
Username: Thehitch
Fla.
Post Number: 87
Thanks h3lt3r_sk3lt3r, I have never used that short cut, I just tried it for the hill of it, kinda like www.morons .com. I would think one of your fav`s is www.illiterate.com!!
I'm having the same problem with Lemon Loader. It doesn't seem to want to load the bin for my techsat receiver. Is there another loader software that I can use to load the new bin.
Thanks in advance for your help!
take sep22 bin/key download it,search channels,bring up key codes(5400),turn off,now download nov 9 fix,plug in and watch tv....i tried the other way but it would not work for me but this does...hope it helps
