while fooling around with n2 keys for the recent change, i accidently deleted all of my channels. i re-blind scanned echo 7 and echo 3 to get the channels back, but what im finding is that both dishes only pick up international channels. ive rescanned several times and reset the factory settings but every time i scan, the reciever (pansat 3500s) only picks up international channels. nothing is wrong with the dish itself, what am i doing wrong? is this common? how can i get my american channels back? ive done a lot of faq reading but can't find anything.
no you have the most recent did you redo the parental control and the nag 2
yup, thats why im able to see the international channels. im thinking it has something to do with the scanning? is echo 3 & echo 7 the right dishes to get both international and us channels?
Check your LNB Local frequency let me know what you see. echo3 is 61W and echo7 is 119W Do you have two dishes? Not sure if this would make a difference. just trying to help.
dssjunkie
Are your sats going to the right ports 119 -1 and 61.5 -2?...And blind scan each sat one at a time.
yea 3 im sure on is international, echo 7 is giving me the same list of channels as echo 3 though which is bizarre. i thought maybe the problem was the way the channels were displayed but after selecting the echostar package under the sat menu, nothing. i dont get any channels below 400 something. Anyone have any ideas?
Update: i just changed the bin to 120 cuz i found it on pantecdvb, but still no change
