Nedd help
larry1425
can anyone please help me find a bin file for a spacestaedvb500
Username: Cryogenic
K-town, BC
www.google.com
larry1425
there was nothing there
Username: Cryogenic
K-town, BC
spacestaedvb500
hmm
Tried Spacestar dvb500 in google
found this
spacestar_050918.bin
dunno if thats old or not
its from september 18, 2005 and its no longer any good.
north ontario
How to flash your dvb500
Follow these instructions to FLASH...........
STEP 1. Connect a null modem cable to your computer and your receiver
(make sure the receiver is plugged in)
STEP 2. Execute the XC-2K232.exe
STEP 3. Click on FIle choose your appropriate RS-232 Comport
(COM1, COM2, COM3 or COM4)
STEP 4. Next screen click on DSTB
Scroll down to Update Software (Safe) F3, click it
STEP 5. A window should pop up
locate and click on the newest flash (The_Asesin_V)
STEP 6. Downloading to your receiver should begin and will take about 3 minutes,
when receiver shows rrrrr on it exit out of 2K232
then unplug the receiver and replug it.
NEW FLASH IS DONE
STEP 7. Execute SatelliteEditor or PCEditor or Channel Master and write the channel list to the receiver
or connect to TV and scan satellites.
** NOTE **
A Null Modem Cable is needed to Flash (9 pin female both ends)
When DOWNLOADING or UPLOADING to the receiver, always watch the
receiver and wait untill it is finished before disconnecting it.
The receive will display rrrr when finished.
http://www.curious-contraptions.com/forums/forumdisplay.php?f=62
