Listen up! Unregistered guest | You get what you pay for! |
Silver Member Username: Thill1951akalkPost Number: 589 Registered: Oct-05 | Its a VERY fast dying breed! |
dssjunkie Unregistered guest | If they can't even come up with a file for key change or even do manual key change with remote SEE YA! I'll never use that peice a SHEIIAT!V1ewsat and P@nsat all the way!!! |
