Need help
Username: Hnic_men
Post Number: 16
i'm setting up my view sat when i go to instaltion it ask me for a pin code can u guys give me some info on how to set up my reciver for dish net already loaded the bin file
Username: Thill1951akalk
Post Number: 246
Go to www.dsscommunity.c om ...Forums...FTA File share area...now download this to your computer...unzip it (use winzip or www.win-rar.com the free winrar 3.51.exe file)...now read it..it doesn't get any easier than this...U've just been spoon fed!
Apt-Get's ViewSat-All-In-1.zip
(size: 704.6 KB last modified: 09-26-2005 )
Complete Viewsat setup package with all files and instructions
Post Number: 248
Its 0000...
Viewsat How-to
WARING: Never connect a satellite cable to the FTA receiver while the unit is ON, always turn off the receiver power when you are making any connection to the receiver.
First is to UNPLUG the ViewSat. Connect ViewSat to computer Com1 Port with Null Modem cable. (Reboot computer, if needed)
2. Open the program "Loader2". Viewsat How-to
WARNING: Never connect a satellite cable to the FTA receiver while the unit is ON, always turn off the receiver power when you are making any connection to the receiver.
2. Open the program "Loader2". Get it here: http://www.satemporium.net/forums/s...2103#post142103 ...or get it at any reputable site with files!
3. Click "Open Files", select "ViewsatUSA_V69.PGM" to flash to STB.
4. Click PC->STB, then Plug In your ViewSat electric power. If you have a Viewsat Platinum connect power first then turn on power switch. (You should see the File loading properly)
5. It's finished when STB displays "End", then "0000". *** WAIT for ViewSat to display "0000" on the front display.
6. AFTER ViewSat displays "0000", UNPLUG your ViewSat. (Turning "OFF" before "0000" will ruin ViewSat!)
7. Connect ViewSat to your TV
8. Connect ViewSat to DiSEqC switch
9. Connect DiSEqC switch to LNB cable(s). 119 goes to Sat 1, 110 goes to Sat 2
10. Plug ViewSat into the wall socket and turn rear power switch "ON".
11. Automatic Satellite Channel Search for 119 Satellite using LEGACY LNB
A. Main Menu---> Installation. Password = 0000 ---> Automatic Channel---> Antenna Setup
B. Select Satellite to be Searched using large Black "LEFT" or "RIGHT" remote ARROW keys
1) 119 Bird = Echostar 7
C. Insert your antenna information (Usually just need to change LNB TYPE and DiSEqC Port #)
D. 119: Echostar 7 using Legacy LNB (Usually just need to change Items 2 and 7)
1) LNB power on
2) LNB type standard
3) LNB freq 11250
4) 22khz OFF
5) TP freq 12224
6) Search option ALL
7) Disecq Port 1
Motor off (if available)
E. Press Remote Control OK; STB automatically searches for all radio & TV channels on bird.
12. Automatic Satellite Channel Search for 110 Satellite using LEGACY LNB (IF NEEDED)
A. Main Menu--> Installation---> Automatic Channel---> Antenna Setup
1) 110 Bird = Echostar 6,8
D. 110: Echostar 6,8 Using Legacy LNB (Usually just need to change Items 2 and 7)
1) LNB power on
3) LNB freq 11250
4) 22khz OFF
5) TP freq 12224
7) Disecq Port 2
Motor off
13. Put channels in order like Dish (To get them in numerical order (100,101,102,105)
1) MENU --> 1. Edit Channels --> OK -->
2) Press "RIGHT" black arrow remote button 4 times to highlight last icon
3) Box below icons will say: "Sort channel list". Press "OK"
4) Press "DOWN" black arrow remote button 4 times to highlight, "Sort by SID"
5) Press "OK"
6) STB sorts channels. When done, press "EXIT"
7) "Do you want to save? Press "YES"
STB updates and saves information. Click "EXIT" once.
14. You are done. Go surf your channels and enjoy!
Username: Jabo2
i`ve tried for two days to find the correct GTROM program to program a skyview500x reciever. can anyone help me?
