Need Help finding Echostar 9
Username: Kev_one75
I have my FTA Pansat set up for Echo Star 6/8 and Echostar 7 on a separate dish, those are working fine. i just got an 80 cm dish from Winegard and i am trying to find Echostar 9, i get the signal but no quality. am i getting no signal because i'm not focused on the proper dish. Any help with dish pointing would be appreciated. First time setting up a dish.
Thanks
Username: Kev_one75
i should add that i'm getting 82% signal but no quality.
Username: H3lt3r_sk3lt3r
Post Number: 202
@bobby
Make sure you're using a linear lnb for 121w (echo9).
You might want to check out this software:
[link removed]
http://www.hollsco.com/Products/SatCalc/
http://www3.telus.net/rampage/skew.htm
http://www.remotesat.com/lookangle.htm
Post Number: 203
@bobby
If you already ARE using a linear lnb, check on your receiver that the settings for its frequency are set to: 10750 instead of 11250.
Username: Kev_one75
I've lowered the dish to the co ordiantes on the satfinder website, but still unable to get the quality signal. I have the Universal Twin LNB 0.3dB Horn. is there a site for settings of the LNB?
Username: Spank
Post Number: 162
What are your settings for Echo9 in your Pansats Antenna Setup screen?
Try setting LNB Type to Universal - 10600
Turn on 22Khz
Username: Kev_one75
sorry i've got the fortec life time ultra receiver, my settings are Universal 10600 but it seems i still cant get any quality even though signal stregth is above 75. does anything need to be done to the receiver?
