Silver Member Username: Slo_hand2Post Number: 102 Registered: May-05 | this file works for the pansat 2700A but will not upload herebecause of size look for X-87BL_050914_114-apiecm09-13fixed. I found it at future-fta.com All channels working |
Anonymous | 2500a ? |
h3lt3r sk3lt3r Unregistered guest | 2500a and 2700a |
h3lt3r sk3lt3r Unregistered guest | Cross the 2500a out for that bin, look for Pansat_251_slow_ecm_09-13-05.BIN on Blacklist's site. |
bulbul Unregistered guest | how about DIGIWAVE ??? is there any solution for it ??? |
Ecclipse Unregistered guest | 2700A bin fix works get it here: http://www.smarthackerz.com |
h3lt3r sk3lt3r Unregistered guest | Ecclipse by now every fta site has it. |
Silver Member Username: Slo_hand2Post Number: 103 Registered: May-05 | Ok BL has an offical update X-87BL_050914_115_api(n) I found it this AM on his offical site. Said to fix the slight freeze between channels. |
reader Unregistered guest | what is the URL of the BL site? |
Silver Member Username: Slo_hand2Post Number: 104 Registered: May-05 |
