What TSOP numbers work? Any similarities?
I Dunno
I hear different numbers on TSOP sufix / combos, anyone try this with enough boxes to know what works and what doesn't so we can rip apart our receivers to see before risk frying something...
Pantec Fortec and pansat are same I thought, why difference in fixes is puzzling...
If we don't get a rock stable fix, maybe we can narrow down where it is most stable at least...
LK
info so far: This "Panster 251 Virus" is focused on the TSOP. If you have a TSOP 29LV800BTC-70 or a 39VF800A70-4C-EX CHIP on your mainboard you are a target. If you have a 29LV800BTC-90 you are ok. Simply put.. if you have a -90 Series TSOP you should be OK.
Assuming U have a genuine (not cloned) receiver, and U put the factory bin or boot repair file on first, before U ever load ANY newer bin/flash on to your receiver..
