p1222sen Unregistered guest | I don't have any equipment at the moment and I'M a newB and with the new new's that came out about N2 I would like to get into testing. What kind of system should I buy and where can I get it? Any help would be great thanks guys |
Anonymous | It depends if you want to get into FTA or plastic. Fta has some early files Cools@t, Pansat DVB and a few others are up. do a little reading. If you are new FTA, would be an easier way to go. As of now there is no way publicly to write to a N2 rom 101, 102 or 103 card. Lots of info out there to read. Good luck |
chicago Unregistered guest | recommend a coo*lsat4000,pansat 2700 from a sponsor at a site like hashu. com,dss-newbie.net,dsscommunity. com...and get the files and info from those forums.. |
p1222sen Unregistered guest | I'd like to go FTA and what is plastic? which setup do you have? When you buy an FTA reciever does it come with a card? |
chicago Unregistered guest | Plastic = plastic access card FTA's do not require cards.. Now go do some reading where I told U..MUCH learning/reading (weeks) to do...obviously U have done none!...people do not get spoon fed in this hobby..U must read and make an effort yourself.. |
Cindy S Unregistered guest | Chicago why doesn't dsscommunity. com keep ther files updated anymore? |
chicago Unregistered guest | they do...they have the newest nagra2 FTA fixs..File Share FTA area..or File Share Dish area.. |
