I am going to buy a Fortec Star Lifetime Ultra and I am going to buy a used Dish 500. If I am correct I have to get the dish with the two seperate LBNs, not the one with the 21 switch built into the head correct? I think this is because the receiver needs to seperate the two sats. Although the DiSEqC 4x1 Switch combines the signal any way, does it work differently than the sw21 switch?? Guidance would be much appreciated.
the Fortec will work with the built in sw 21 but you need a modified chanell list.
ahhhhh
just looking throught he posts and ya just answered my question thank you
Yep they're at it again, New keys are as follows. Key 00 is only one needs to be changed to get tv back, but look for them to roll every 48 hrs. now as Dishnet goes to war against FTA.
Key 0=F0 C9 59 D8 7F 8D 34 13
Key 1=82 D7 51 E4 5B 97 9D 81 for more info like this go here satellite portal
