Unregistered guest | I got a descrambler from a friend of mine who isn't using it anymore. I use cablevisions IO box. I think I need to program the descrambler because there are two buttons when you open it up. After connecting it, it doesn't seem to work. I don't have the instructions on what to do with the two buttons in order to program it. If anyone can help, I'd really appreciate it. Thanx in advance. |
Anonymous | If you are talking 'bout an rft then throw that junk away and get a test chip. Test chips are cheaper descrambler devices that work with the original oem boxes provided by the manufacture (which most cable companies use). You can get awesome unbeatable prices on test chip descrambler for cable box like Jerrold (or general instruments) scientific Atlanta tocom zenith pioneer and more from www.newelectronx.com. Good luck.. Ps they have quickboard super j 4w c-244-4w r2/v5 starcom-6 for cft2014 cft 2200 cft2254 sa8600stnn and stuff |
