New member Username: AlienlocoPost Number: 3 Registered: Sep-04 | Hi I have a single dish with one LNB at 91W www.bell.ca Some of the payperview and sex channels are not working any one know how to fix that ? Thanks |
JCHq Unregistered guest | yes stop watching the sex channels ;) |
Horndawg Unregistered guest | Get your hand off your cack and check your transponders, make sure you have at least an 80% on all of them. |
New member Username: AlienlocoPost Number: 4 Registered: Sep-04 | Hi Sounds good I am going to try to change the transponders, I do not care so much about the sex channels, but I will like to get more payperview channels Thanks |
Dukester Unregistered guest | How do you achieve at least 80% on each of the Transponders? Thanks |
