Username: Jaggatorman Post Number: 1 Registered: Sep-10
Sunday, September 19, 2010 - 18:12 GMT I currently have my LCD TV hooked up to my receiver and speakers for surround sound. I would like to be able to listen to the cable music channels through my stereo system with the television turned off. I must have something not connected correctly. Any suggestions... Thanks.
Username: Plymouth Canada
Post Number: 14768 Registered: Jan-08
Sunday, September 19, 2010 - 20:58 GMT Welcome to eCoustics Paul! Use 2 ''Y'' cable splitter then hook it in another input of your receiver! It will worked only if you have a Cable box to select your channels, if not forget it because your TV tuner doesnt work with the power off.
Username: Jaggatorman Post Number: 2 Registered: Sep-10
Monday, September 20, 2010 - 01:05 GMT Plymouth, thank you. I do select my channels through the cable box. I will try the "y" cable splitter.
Username: Mccambley BREEZY POINT,
NY
Post Number: 785 Registered: Jun-05
Tuesday, September 21, 2010 - 19:33 GMT No Y splitter needed. Hook up your cable box directly to the reciever to cable/sat in.
Username: Vm8444 TorontoCanada
Post Number: 315 Registered: Aug-05
Wednesday, September 22, 2010 - 01:38 GMT with digital coaxial or optical cable
Post Number: 14833 Registered: Jan-08
Wednesday, September 22, 2010 - 03:43 GMT Yeah Casey! He can hook it directly in the receiver vince Digital or coaxial can do on new stereo system only! Good choice with better sound but cable box does not sound great usualy!
Post Number: 316 Registered: Aug-05
Wednesday, September 22, 2010 - 14:43 GMT Plymouth my reciever is 9 years old mine has many digital and optical inputs and cable box does sound better then tuner from tv when hooked up directly from cable box to reciever. theaudioguy.ca
Post Number: 14834 Registered: Jan-08
Wednesday, September 22, 2010 - 16:29 GMT vince I totally agree with you! 9 years ago it was an option but today it's standard! I personnaly use the optic input with my Yamaha 7.1 to get AC3 sound then HDMI for other source! I I said that because he can have the sound on the TV without using the strereo system!
Post Number: 317 Registered: Aug-05
Wednesday, September 22, 2010 - 22:37 GMT cool
