New member Username: NtlchrisPost Number: 1 Registered: Mar-10 | Hi All I have to plan to connect my laptop HP Pavilion dv1000, and 777 Pioneer DVD home theater. Audio out from Laptop to DVD home theater. Which cable can i use? 2 Female RCA cable is working? Thanks & Regards |
Gold Member Username: JrbayLivonia [Detroit area], Michigan USA Post Number: 1184 Registered: Feb-08 | Greetings Chris, If you plan to take the audio out of your laptop from the headphone jack then the cable you need is called a 3.5mm stereo to RCA cable and looks like this: http://www.google.com/products/catalog?source=ig&hl=en&rlz=1G1ACAW_ENUS357&q=3.5 mm+to+rca&um=1&ie=UTF-8&cid=4143817684018793328&ei=BregS4LLL4LUNbfn6dgM&sa=X&oi= product_catalog_result&ct=result&resnum=3&ved=0CCgQ8wIwAg#ps-sellers |
New member Username: CnuPost Number: 4 Registered: Mar-10 | u can use 3.5mm to rca cable to connect however u will have stereo sound at your home theatre not the full hd experience.... |
Gold Member Username: JrbayLivonia [Detroit area], Michigan USA Post Number: 1197 Registered: Feb-08 | "FULL" HD experience would be digital but if the computer's sound card is analog then signals from the headphone jack carries the surround information. |
New member Username: CnuPost Number: 5 Registered: Mar-10 | Right now there are sound cards with coax output which are digital....some reatives and so many....u can google them...cheers ![]() |
New member Username: NtlchrisPost Number: 2 Registered: Mar-10 | Thanks for the tips.I will try it. Best and Regards |
