Is it wise to run 8 ohm speakers with a 6 ohm amp?
Username: Jaystone
Kingston, Ontario Canada
Thinking of buying a yamaha rx-d202b or rx-d302b.I believe they put out 100 and 110watts x 7 @6 ohms respectively.Is it wise to run 8 ohm speakers or should I reconsider and get a different amp altogether?
Username: Project6
Post Number: 11087
They will be fine. Problems usually arise when the impedance load is too low, such as using 4 Ohm speakers with an amp that is designed for 8 Ohms.
Username: Nuck
Post Number: 4204
And yes, Dennis, you should consider another receiver altogether.
Username: Samijubal
Post Number: 3064
Those are JVC model numbers. The Yamaha receivers have a switch for different speaker ohms, I don't know about JVC.
