Best surround speaker system
Username: Cutlass372
Hello everyone. I have been looking at a few speaker systems for my room. I have been looking at the Athena micra 6 Along with the Infinity Tss-450. I would only like to spend around 300 dollars for this. I will be using my mini hi fi receiver 2 push this (it is alreasy pushing 6 speakers fine. What speaker system do you guys recommend for around 300 or cheaper. I would like something like 6.1.
Thank you, Elliot.
Username: Project6
Post Number: 6003
That's not a bad choice at all and should work well with your current set-up.
What mini hi-fi receiver are you using?
It is the Philips Fw-C70 i have had it for a long time now and its really been proving itself. It can make my music very loud and very clear. I juat want some surround and a sub 2 go with it. what ones would u recommend??
Username: Project6
Post Number: 6006
The micra 6 is a great unit and should already have a sub that goes with it.
You know where I can get it the cheapers??
You know where I can get it the cheapest??
Oh yeah also I believe the Reciever is 6 ohms and the athena micra 6 is 8 ohms. Does that matter???
Username: Project6
Post Number: 6014
That unit should work with your unit. The impedance should be okay as long as you don't use 4ohm speakers. I am just not that familiar with boomboxes and why you would want to expand that unit. It would be better if you get an inexpensive receiver for those speakers in the near future.
You should also be mindful of the speaker output terminals that your boombox uses.
Username: Project6
Post Number: 6017
Try bestbuy or audiadvisor.com
wouldn't I just be able 2 put the speakers in the high level inputs in the back of the sub then hook the sub 2 the reciever??
Username: Project6
Post Number: 6030
yes.
you're not planning on using the existing speakers are you?
Post Number: 7
Yes I am. I would like to have the 6 speakers i ahve now along with this extra set.
Username: Project6
Post Number: 6032
What do you think this will achieve, though?
Post Number: 8
What???
Jamster
You'll have to forgive Berny, he's an idiot.
Username: Project6
Post Number: 6072
Nevermind.
Username: Roberts
Redmond , WA USA
Post Number: 9
My Krell system is great for surround sound but a bit expensive.
Jamster
You look like an idiot too Robert Smith. He did not ask about expensive stuff and he don't need lies from a poser idiot like you.
Sure you have a Krell, you are so full of crap I can smell you from here.
