I just bought the new Benq pb6100 projector and I am planning to set it up very soon. My question is this. I do not know whether to set it up on a somehat jagged or uneven larger white wall or a smaller, very flat white wall that leaves less space for seating and my surround sound. This is only temporary until I pick up my da-lite screen but which one should I go with and will the jagged wall be unbearable to look at? Thanks.
Go for the best speaker / seat setup.. afterall, the screen is on its way and the wall is only a temporary thing. You'd forever kick-yourself if you went with the best short term solution and it detracted from future viewing.
Besides.. once the screen arrives.. think of the 'wow' factor between that surface and the wall!!
I watched mine on a large white bedsheet for a couple of weeks until my screen arrived.. maybe you could try that as a temporary fix?
