New member Username: HusquaPost Number: 1 Registered: May-12 | Hi! I unplug my bell express vu 5900 for 6 mounths and now when i re-plug it back all channel is lock.It is asking me to enter pass word but I don't know any pass word . I try a hard reset Menu,6-3 info right-left and check line NVM 0320 and all I have is four columm first colum all 0 second columm all 0 thrid columm 001800 last columm 000001 I try to enter these code but still lock i don't know if NVM0320 is the right columm for my 5900? I did the same reset sequence but put tv/video and did the OK then unplug the power still lock. I would appreciated any help |
New member Username: HusquaPost Number: 4 Registered: May-12 | Hi! Now I can see all my channel but the padlock is lock and if I go to lock option 5 it is asking me for pass word . For a 5900 where can I see my pass word it isNVM 0320?? anybody could help me here |
Gold Member Username: RunnerguyPluto Post Number: 2740 Registered: Sep-06 | Hi! Paul!! You are Chodu bhagat |
Gold Member Username: PulpfiktionPost Number: 1145 Registered: Mar-08 | paul..... zulu is a bad bad boy. Wait... Subash or sad will answer to u....ok |
New member Username: HusquaPost Number: 5 Registered: May-12 | Hi! I was under the impression that sattelite receiver expert was on this web site i guees I was wrong |
Silver Member Username: EldonperritoHuntington Beach, California Usa Post Number: 298 Registered: Mar-11 | Mr,Culo you fucked up idiot,if you won't help go get f uck by your neighbor's dog you b itch. |
New member Username: HusquaPost Number: 6 Registered: May-12 | Is that the way you fix a problem in the golden state????? |
Gold Member Username: KrishnPost Number: 2006 Registered: Sep-06 | paul - seems you have a bell sub reset |
New member Username: HusquaPost Number: 7 Registered: May-12 | Hi! I dont understand your answer about bell sub reset?? maybe clarify your answer please. Thank you |
Silver Member Username: Tommy_hPost Number: 487 Registered: Jan-12 | " bell sub" = your paid subcription to Bell TV. The link is to "reset" your password giving them your information, which is on that page subash gave you. Jusy follow the steps. |
