Hi Subash, I performed TP scan of 12172 with out any luck then I deleted all the channels from 18.8 west satellite and blind scaned all the channels. All channels were scanned and working but I don't see any cricket channels 576, 582 and 584. Any advise? Thanks.
Save all your channels, then delete only 118, set the frequency of 118 to 10600 (if it was at 10750), do a scan of 118, you might get those channels, however transponder frequencies will show 150 less for all transponders.
Lyngsat does not have those ID's for cricket channels, most of the recievers these days do not show id's like Pansat used to show, not sure present bin for Pansat shows ID's in channel edit either.
Rizvi: The original 118 LNBs came out with a LNB freq of 10750. Later some had LNB freq of 10600 and/or 10750. As Subash suggested, try a scan with a freq setting of 10600. Yo will get some missing lower freq channels. Also try a blind scan.
