Hello to all members, I'm currently using my Dreambox 500s and was thinking of purchasing the WFC for my Viewsat ultra which has been collecting dust since N3. Hoping to get some people's feedback who are currently using the WFC with there Viewsat receiver. Are you happy with the stability of the product (does it go down alot). Is it easy to setup. Or basically is it worth purchasing. Thanks for any input.
All I want to know, is if current wfc users would recomend this product to people like myself who are not sure if to purchase or not. Please some feedback.
Dreambox500sguy......message #1 Hoping to get some people's feedback who are currently using the WFC with there Viewsat receiver. Are you happy with the stability of the product (does it go down alot). Is it easy to setup. Or basically is it worth purchasing. Thanks for any input.
Dreambox500sguy......message #2 October 04, 2010 - 04:24 pm: All I want to know, is if current wfc users would recomend this product
Damm Nydass, after 4 years here and still in the dark
Cooler King: No thanks for your interuptions. Answer the man instead of hounding me. Now get lost.
"m currently using my Dreambox 500s " Q. with private IKS or Public. Q. What channels do you want to watch on Viewsat, since each of the receiver's IKS gives different channels?
"and was thinking of purchasing the WFC for my Viewsat ultra which has been collecting dust since N3. Hoping to get some people's feedback who are currently using the WFC with there Viewsat receiver. Are you happy with the stability of the product (does it go down alot). A. It goes down a lot for some channels and does not go down for others. Q. What channels do you want to watch on Viewsat?
Is it easy to setup. A. Yes - as difficult and as easy as any other receiver.
Or basically is it worth purchasing. Q. What channels do you want to watch on Viewsat? Q. Are you prepared to modify your viewing, by watching other channels?
