Hi I know the Solaris and the Neosat ipro1k are basically the same box, with interchangeable Files!
I also know that the ipro1k is MORE STABLE than the Solaris, that's why I would like to convert, but, I need to upload the NEWCAMD files. I use a PS (Not NFPS!)
I tried to convert my Solaris to a Neosat ipro1k but, the Solaris DOESN'T have a USB Port needed to Upload the ipro1k Files. So HOW can I get and UPLOAD the ipro1k NEWCAMD and other files?
I found a Loader for the ipro1k that will work with my Solaris though, but, don't know if this will work!
I've done the like a semi-conversion BUT don't get the NEWCAMD file that's needed to get the NEWCAMD to fill out my PS IKS Info!
Can I get ALL these Files for the Convertion here?
Also the reason I want to convert is to have EPG (Will converting to ipro1k ... give me EPG)?
Thanks for all the help I can get, ... I really appreciate it!
