72.7 question
Username: Lroy
Post Number: 561
Is anyone getting any HD channels on 72.7 with NF HD.....
Username: Nydas
Post Number: 19348
As far as I know, none of the IKS services are giving service for the 72.7 bird.
Username: Lroy
Post Number: 562
Thanks nydas....
Username: Zja
YES YOU CAN GET HD CHANNELS ON 72.7 BUT YOU NEED TO CHANGE ALL THE TPS ON THE SATELLITE
Username: Lroy
Post Number: 563
CHANGE THE TPs TO WHAT VALUE...
Username: Lroy
Post Number: 564
RE THE ABOVE THREAD, ALREADY LOADED THE LATEST TRANSPONDER JULY 13 FILE, IS IT STILL NESCESSARY TO CHANGE THE TPs IN ORDER TO GET THIS BIRD..
Username: Zja
yes you do. change it to sk 21500 dvb 8psk auto, and you will get all the channels
Username: Dispatch_69
Israel
yes you can get it.......
