Whats wrong with satfix ? taken ?
Username: Lomna
Sac, Calif U.S.A
Post Number: 1289
Any clue.
Username: Nydas
Post Number: 19321
This is what I get when I go to the satfix/net URL
"Web Server's Default Page
This page is generated by Parallels Plesk Panel, the leading hosting automation software. You see this page because there is no Web site at this address.
You can do the following:
* Create domains and set up Web hosting using Parallels Plesk Panel.
* Use Parallels Virtuozzo Containers with Parallels Plesk Panel to set up domains (Web sites) in virtual dedicated servers. Using a number of virtual servers with Parallels Plesk Panel on a single machine allows for flexible management of your server's resources.
For more information please contact Administrator."
I suspect they are changing servers.
Username: Danoh
Post Number: 145
i just got in no prob..clear cookies and retry
Username: Nydas
Post Number: 19328
Yes - it works if you remove the satfix.net cookie in your browser.
Thanks Dan
Username: Lomna
Sac, Calif U.S.A
Post Number: 1290
Huh, it was out of reach few hrs ago. Thank god its back.
