Silver Member Username: Robbie12Post Number: 129 Registered: Jun-06 | hi, is it possible to capture the echostar 3 at 61.5 in vancouver, canada? if yes, what are the settings for the 9000 hd? i have been trying to get the signal but no luck, i am using a 24 inches dish which was working properly for echostar 10/11 at 110. thank you. |
Platinum Member Username: NydasPost Number: 19410 Registered: Jun-06 | The footprint of 61.5W shows that Vancouver is covered. You might try a 30-33" dish http://www.satbeams.com/footprints |
Silver Member Username: Robbie12Post Number: 130 Registered: Jun-06 | i will do that, thank you nydas. you are always helpful. |
Platinum Member Username: PlymouthCanada Post Number: 14441 Registered: Jan-08 | Robert Get a 36'' you will have a better signal! |
Silver Member Username: Robbie12Post Number: 131 Registered: Jun-06 | ok, i bought a 36 inches dish, i am using the same lnb for 110/119. my settings are : standard, 11250 and still no luck, what is the issue? |
Silver Member Username: ChaffPost Number: 492 Registered: Jan-10 | You could ...go here, The HD TP's are 8psk, sr 21500, fec 2/3 |
Silver Member Username: Robbie12Post Number: 132 Registered: Jun-06 | ok, i have got the signal from 61.5 i made a channel scan, i got 33 channels but none of them is working! all are scrambled channels, aren't those channels supposed to work with the weather forecaster? |
Platinum Member Username: NydasPost Number: 19413 Registered: Jun-06 | I think the WF and most IKS only give you 110/119/118 |
Silver Member Username: Robbie12Post Number: 133 Registered: Jun-06 | why i did not think of this issue before buying the dish. anyway, thank you for the help. |
Platinum Member Username: PlymouthCanada Post Number: 14449 Registered: Jan-08 | Robert Sorry! I don't have the latest channel list! Which channels you are looking for? You can use this dish to get some free to air channels! |
Silver Member Username: Robbie12Post Number: 134 Registered: Jun-06 | i am looking for the Arabic Package (al arabiya, mbc, lbc ....) |
Silver Member Username: ChaffPost Number: 493 Registered: Jan-10 | You could.. . check the 118 sat , it might have the channels you want-, if so , get new lnb ("Circular" 118°/119° 10750) for the 36" dish and aim at that sat. |
Platinum Member Username: NydasPost Number: 19415 Registered: Jun-06 | Robert: Re. Arabic channels. Just to avoid cconfusion. With a DN subscription, and IF the arabic package is on 65W, you should be able to get it with a larger dish because of the weaker signal in the West coast. You WILL also need a Dish receiver with current subscription paid for those channels. If you are looking for Arabic channels via IKS on a FTA receiver, this is only available from 118W (ANIK F3). For that you need the 33" dish, a special 118/119 LNB with LNB freq. of 10750 0r 10600.. Also note that as if now, the IKS support for 118 is down. There is upport only at 119 and possible for 110W. |
Bronze Member Username: Pancho_viliaPost Number: 30 Registered: Aug-10 | Robert Pelligrini point you Dish to Galaxy 19 at 97.0°W change your LNB to Linear,pop an Arabic Beer watch Arabic TV All FTA Ku-band channels in Arabic Note There are a lot of Arabic channels available on North American FTA, more than any other non-English language. Channel Name /Satellite Freq /Pol SR VPID APID 2M TV www Galaxy 19 11991-V 22000 272 273 Abu Dhabi Sports www Galaxy 19 12145-V 22000 2026 2036 Al Alam News www Galaxy 19 11836-V 20765 408 356 Al Anwar www Galaxy 19 11929-V 22000 2010 3010 Al Fayhaa www Galaxy 19 11966-H 22000 202 201 Al Hayat www Galaxy 19 12060-H 22000 2010 3010 Al Kalema www Galaxy 19 12115-V 22426 2600 2601 Al Kass www Galaxy 19 12083-V 22000 357 358 Al-Forat www Galaxy 19 12053-V 22000 1376 1377 Al-Iraqiya www Galaxy 19 12145-V 22000 2025 2035 Alkarma TV www Galaxy 19 11789-V 28125 4027 4036 Almaghribya TV Galaxy 19 11789-V 28125 4023 4033 Ashur Satellite TV www Galaxy 19 11929-V 22000 2007 3007 Canal Algerie www Galaxy 19 11789-V 28125 1260 1220 Coptic TV www Galaxy 19 11867-V 22000 4194 4195 Hope Sat TV www Galaxy 19 12090-H 20000 4863 4864 Jordan TV www Galaxy 19 12145-V 22000 2073 2083 Kuwait TV www Galaxy 19 11991-V 22000 320 321 Kuwait TV 3 www Galaxy 19 11789-V 28125 848 849 Libyan Jamahiriya Broadcasting www Galaxy 19 12145-V 22000 2072 2082 LLBN Arabic www Galaxy 19 11842-H 22000 2012 3012 Logos TV www Galaxy 19 11867-V 22000 33 32 Middle Eastern American www Galaxy 19 12115-V 22426 1280 1281 MTA1 www AMC 3 11735-V 8333 102 103 MTA1 +3 hours www AMC 3 11735-V 8333 302 303 MTA3 Al-Arabiyya www AMC 3 11735-V 8333 402 403 Payam-E-Afghan TV www Galaxy 19 12122-H 20000 783 784 Qatar TV www Galaxy 19 12145-V 22000 2071 2081 Salaam TV www Galaxy 19 11929-V 22000 2005 3005 Saudi Arabian TV 1 www Galaxy 19 12145-V 22000 2024 2034 Saudi-Quran Galaxy 19 12152-H 20000 1024 1034 Saudi-Sunnah Galaxy 19 12152-H 20000 1025 1035 Sharjah TV www Galaxy 19 12145-V 22000 2027 2037 Sudanese Space Channel www Galaxy 19 12145-V 22000 2023 2033 Sultanate of Oman TV www Galaxy 19 12145-V 22000 2028 2038 Syria Drama Galaxy 19 11789-V 28125 1104 1105 Syria Satellite Channel www Galaxy 19 12145-V 22000 2021 2031 The Truth www Galaxy 19 12060-H 22000 2024 3024 The Way www Galaxy 19 12022-V 22000 4255 4256 Tunis 7 www Galaxy 19 11836-V 20765 262 263 Yemen TV Galaxy 19 12145-V 22000 2022 2032 |
Silver Member Username: Robbie12Post Number: 135 Registered: Jun-06 | Hombre, thank you for your help, i already have those channels but the rest i am looking for are better, thank you chaff for your help. Nydas, those channels are also available on Echostar 14 at 119W, is this satellite supported by the WF? thank you in advance for your help. |
Platinum Member Username: NydasPost Number: 19417 Registered: Jun-06 | "on Echostar 14 at 119W" Look also at IKS does support Arabic channels of 118, but at present they are down and have been down for a couple of weeks. |
Bronze Member Username: Pancho_viliaPost Number: 31 Registered: Aug-10 | Hey Robert check this Link out 4 days ago. I have no idea what or who is NPFS |
