i am hooking my wf following all instructions from fta bin & ftacp. i get the following reading : new software : DX - X00 - N APP 2.00.03 network s/w version : DX-X00-N APP 1.00.00 2ND line should read same as first. dont know why i dont get it the same
i am getting the 2 lines the instructed readings already : DX X00 N APP 2.00.03, but no chANNELS. ANY BODY OUT THERE CAN HELP ME WITH THE WF PROGARM. WHAT IS THE INTERNET SPEED NEEDED?
Usualy on all IKS system you must do a scan after you put the file, try it, I don't have much info on this WF but can do a search if you still have problem!
Posted by darkstknight1523 - Junior Member on 04-11-2010, at 09:17 PM
C/P 'While reviewing the settings after flashing and all, I see that the S/W Version remained DX-X00-N APP 1.00.03. After upgrading the Network S/W the "no video or audio" went away and I'm clear. Hope this helps if anyone has similar problems.'
now. i am missing : PPV , local , foxsports ( only when the ball games are on ). is it possible to get them thru another set up? where is the channel list for the wf.?
