Ok RTN Again
Username: Lauchie411
Inverness, Nova scotia Canada
Post Number: 120
I finally got this dish on the sat. Then i try as i may i can get the rtn codes to go into the VS ultra Lite. I'm getting the CCTV channels but no RTN, I tried for awhile and nothing seems to work. I have a friend with a view sat ultra. If i can't get this then is there anyway to clone his receiver. Or if someone has a video on how to but these codes that would be great. HELP HELP, lol
Username: Plymouth
Post Number: 13758
laughlin
Your friend can put the program the satellite list and the channels list in the upgrade menu on a USB Key then you only have to copy it in your receiver!
Username: Chaff
Post Number: 192
The instructions reference provider id 0106 - you would use the one(s) for rtn C801 C901
C/P
How to add provider ID-
GO TO MENU, USER SETTING, CODE MENU
SET CAS TO NAGRA
CURSOR DOWN TO HIGHLIGHT SAT NAME AND ID NUMBER
PUSH F1 ON REMOTE TO ADD PROVIDER ID
NAME THE UNKNOWN SAT F2 TO SAVE
FIRST SET OF ID NUMBERS ARE NOW HIGHLIGHTED,
ENTER 01, THEN CURSOR RIGHT TO HIGHLIGHT THE SECOND DIGITS, ENTER 06,
THIRD DIGITS ARE 00.
iT SHOULD LOOK LIKE THIS, 01 06 00.
tHIS IS THE NEW PROVIDER ID, DISH - 01 06 00
PRESS CURSOR UP TWICE, FIRST FF ON THE RIGHT OF WHITE LINE SHOULD BE HIGHLIGHTED.
PRESS FAV BUTTON TO ADD ROWS OF FF'S UNTILL YOU HAVE FOUR ROWS, LIKE THIS;
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
SCROLL UP TO TOP LEFT FF AND CHANGE IT TO 08
THEN CHANGE THE OTHERS BELOW IT TO 09, 88, 89. lIKE THIS;
08 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
09 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
88 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
89 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
THEN START ENTERING THE 0106 KEYS TO THE RIGHT OF THE WHITE DIVIDER LINE.
ONLY EIGHT KEYS ARE USED PER ROW, THE LAST EIGHT ARE CHANGED TO 00, LIKE THIS;
08 3F AD 30 1F A0 CD 9E CE 00 00 00 00 00 00 00 00
09 54 69 8E 15 B3 65 09 FC 00 00 00 00 00 00 00 00
88 9F 41 6C AB 68 19 BA 98 00 00 00 00 00 00 00 00
89 2D 2E 77 FB 01 72 97 7A 00 00 00 00 00 00 00 00
another set of instructions say to press sat button to save after you enter the new provider and its ID
1) First, arrow left or right to pick the correct encryption protocol for the key you're adding, such as Nagra.
2) Hit F1 and enter the name of the provider.
3) Hit F2 to save it.
4) Enter the Provider ID.
5) Finally, you must hit the SAT button to save it (this isn't shown at the bottom of the screen like the other steps are).
Its easier with cw600s 'cause all you do is press page down and enter the key - no need to enter provider id
Post Number: 121
ok nothing workin.....crap i must be slow lol
Post Number: 122
I tried the USB thing Plymouth but nothing worked....Loading those codes i must be making a mistake somewhere as it's not working....wow will plug away at it lol....might here me yelling where you live if i can't get it lol
Username: Chaff
Post Number: 193
You could set up two rtn's with one as provider id c801 and the other as c901....then enter the keys at both , the 08 line should start with E1.
Username: Plymouth
Post Number: 13760
laughlin
I don't know if you can add those provider keys on your VS Ultra Lite!
It work well on the Ultra!
Post Number: 125
my friend has ulta,,,i have ultra lite here,,,,,so it won't work
Post Number: 126
i have cctv, and rtn channels i get picture and sound on cctv and no audio or video////i do have a cw600s anyway to get itt to work...either one
Username: Chaff
Post Number: 194
The cw600s ...when on rtn channel press page down on remote ..edit keys with red button...you will need to enter the 00 key only..select OK when done...you may have to do this ( page down and enter keys)twice as the first time you enter keys it will be under nag2 and the second time it will come up as nag1 when you press page down..
I didn't see the lite in your post about the vs ultra,, it might not support N1.
Username: Plymouth
Post Number: 13763
laughlin
Post Number: 120
Posted on Monday, April 26, 2010 - 03:04 pm:
Post Number: 129
sorry that should read not get the codes in the ultra lite
Username: Chaff
Post Number: 195
Thanks plymouth....
Username: Plymouth
Post Number: 13782
OK
I tested with my CW600p but I can't get the RTN channels, only CCTV work fine but they are not encrypted!
Is those keys are good????
Username: Plymouth
Post Number: 13783
OK! Finally it work now!!!!!!!
Here is the good thing to put in your receiver:
Nagra 1
00C801 00 E134079992603E3B ;RTN (95.0W)
00C801 01 AF96389F9259304A ;RTN (95.0W)
00C901 00 E134079992603E3B ;RTN (95.0W)
00C901 01 AF96389F9259304A ;RTN (95.0W)
Enjoy!!
Shaff you furnish bad keys!!!!!!!!!!!!
WHY???
Username: Chaff
Post Number: 206
WHY???
I didn't furnish any keys
C/P
Username: Plymouth
Post Number: 13785
Chaff
That was not clear for a newbies!!!!
Identifier are 00 C8 01 and 00 C9 01 not C801 and C901 as well that for 08,09 and 88,89 which are 00,01 and 00,01
If laughlin tryed with your post, he will never get it!!
Are you able to get it??
If not! Why you answered him!
Username: Chaff
Post Number: 207
I only enter c801 for coolsat and with the cw600s I didn't even have to enter the provider id
Username: Plymouth
Post Number: 13786
Chaff
I have a CW600p then look what I must enter in add new keys:
Red Button>00C801 00 E134079992603E3B>OK
Red Button>00C801 01 AF96389F9259304A>OK
Red Button>00C901 00 E134079992603E3B>OK
Red Button>00C901 01 AF96389F9259304A>OK
Your C/P from another site doesn't work for CW!
Username: Chaff
Post Number: 208
Its not a c/p--I gave simple instructions, you were not able to follow them- that's OK
did you page down when on an rtn channel and have active key menu displayed or did you go in thru the menu and have to enter all the unneeded keys...
Username: Plymouth
Post Number: 13793
Chaff
Page down doesn't work! I must go to the Key menu!
I think that you have a RTN ready file with the identifier already in your receiver, that's why it worked for you!
My Provider Identifier was not there!
So all keys are needed for me!
