Platinum Member Username: PlymouthCanada Post Number: 13669 Registered: Jan-08 | All receivers have a S/PDIF output, this output can provide AC3 encoding sound! On many channels like PBS which is free to Air, you can't hear the sound in AC3 even if you have HD receiver, you can hook this optic output to a good Home Theater Amplfier and get the sound! I tested this output with my new Yamaha Amplifier and it work great! |
Platinum Member Username: PlymouthCanada Post Number: 13670 Registered: Jan-08 | AC3 sound is available on AMC-21 125W on PBS as well that Telstar 14 63.0W for ETV also! Many encrypted HD channels are up on sound only with the AC3 using! |
Silver Member Username: BernardmiPost Number: 800 Registered: Dec-07 | PBS on Telstar 14 at 63W ??? The satellite only beams to South America Plymouth. |
Platinum Member Username: PlymouthCanada Post Number: 13671 Registered: Jan-08 | Bernard I can get 10 ETV channels on Tp 11963 V 11280 3/4 |
Silver Member Username: BernardmiPost Number: 801 Registered: Dec-07 | I dont get it Plymouth... You cannot receive 10 channels on 11963V on Telstar 14 Telstar 14 is Brazil and Mercosul only and there is NO 11963V transponder on it. It is something other than Telstar 14 ! What is it ? |
Silver Member Username: BernardmiPost Number: 802 Registered: Dec-07 | Oooops.... there is a North American transponder at 11959... Sorry Plymouth. Lyngsat shows FEEDS as description. |
Silver Member Username: Pancho_viliPost Number: 168 Registered: Feb-10 | The Outer Limits, Plymouth is telling you the truth there are 10 channels listed 301 thru 310 5 channels are on right now. ETV Satellite Services http://www.scetv.org/ Btw..........there is a North American transponder at 11959, Yes, but nothing on it as of now. |
Silver Member Username: BernardmiPost Number: 803 Registered: Dec-07 | Interesting info and thanks for the link ! |
Silver Member Username: BernardmiPost Number: 804 Registered: Dec-07 | Has anyone found PBS'es V-me at other place than AMC-1 125W ? I can't see at 125W !!!! |
Platinum Member Username: PlymouthCanada Post Number: 13674 Registered: Jan-08 | Bernard Why you can't get 125W? You don't have a clear sky to point it? |
Silver Member Username: BernardmiPost Number: 807 Registered: Dec-07 | Yup ! Backyard full of trees. Satellite calculator says 16 degrees elevation for 125W. That is terribly low. Mont Bélair might even be in the way !!!!!!!! |
Platinum Member Username: PlymouthCanada Post Number: 13675 Registered: Jan-08 | Bernard Worry for you because those channels provide very good quality for picture as well as sound! |
Silver Member Username: ChaffPost Number: 178 Registered: Jan-10 |
Really ?.... |
Platinum Member Username: PlymouthCanada Post Number: 13732 Registered: Jan-08 | Chaff Really what? |
Silver Member Username: ChaffPost Number: 181 Registered: Jan-10 | Don't be stupid ......I quoted you HD receivers not able to decode AC3 ...you numbskull...LOL |
Platinum Member Username: PlymouthCanada Post Number: 13738 Registered: Jan-08 | Chaff Most of HD receiver can decode AC3! Why you are so stupid? |
Silver Member Username: ChaffPost Number: 182 Registered: Jan-10 | Slymouth , this is what you posted On many channels like PBS which is free to Air, you can't hear the sound in AC3 even if you have HD receiver |
Platinum Member Username: PlymouthCanada Post Number: 13745 Registered: Jan-08 | Poor idiot! I also posted: On many channels like PBS which is free to Air, you can't hear the sound in AC3 even if you have HD receiver,you can hook this optic output to a good Home Theater Amplfier and get the sound! Stop your stupid arging which is only to bash me! |
Silver Member Username: ChaffPost Number: 183 Registered: Jan-10 | Not bash you ...it is to correct you... do you know what month this is ? - IKS Status 02-19 10 |
